Montag, 18. Februar 2008, 18:04
Für alle die genug vom A und B-Proramm haben
hi
für alle, dies interressiert und mal was anderes fliegen wollen....
ich hab auf rcgroups.com das programm fürs e-toc 2008 gefunden!!
hf!!
mfg michi
1) Take off.
180 degree turn away from flightline.
Straight and level pass.
Take off is judged.
K1
2) 45 degree up line.
1/4 roll to Knife edge.
Knife edge climb on a 45 up line.
3/4 roll on 45 upline.
Push to level.
Exit upright.
K3
3) 1/2 square loop, Knife Edge Exit.
Push to vertical down line.
Yaw to exit knife edge and crossing the box.
(Radius top and bottom corner needs to match. Must show a line
between top and bottom corner.)
K3
4) 360 degree Rolling circle.
First 180 degrees 3 rolls to the inside.
Next 90 degree, 3/4 roll to the outside.
Last 90 degrees, 4 of 8 point roll to the inside.
Finish inverted crossing the box.
K7
5) Tail Slide.
Wheels up.
Exit upright crossing the box.
K4
6) Flat rolling S.
4 point roll to the outside first 180 degrees.
8 point roll to the outside second 180 degrees.
Finish upright crossing the box.
K6
7) 90 degree turn
Upright, 90 degree flat turn
K2
8) Roll and Snap combination.
1/4 roll to KE
1-1/2 positive snap opposite direction to KE
2 of 8 same direction to inverted
1-1/2 roll opposite direction.
Exit upright.
K7
9) Stall Turn.
3 of 4 point roll up.
¾ roll down.
Exit inverted.
K5
10) Rolling loop.
1/2 roll up.
1/2 roll down in opposite direction.
Exit inverted.
K5
11) 1/2 square loop with torque rolls.
Push to vertical.
Perform torque roll. 1 turn.
1 turn opposite direction torque roll.
Push to complete 1/2 square loop.
Exit level and upright.
K5
12) 360 spiral turn to landing.
360 degree turn descending to landing.
Landing is judged.
K3
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »michi386« (18. Februar 2008, 18:06)
