Old_Pilot
  • »Old_Pilot« ist der Autor dieses Themas
Beruf: Retired Engineer
Donnerstag, 6. Mai 2021, 16:57
Northrop YA-9A Foamie
Our club has a Scale/Warbird Fly-In coming up in early June, and I've been trying to decide what to build.......
Finally settled on the Northrop YA-9......I built her a year ago and she died due to a dumb electrical mistake
on my part.....Gonna try again
48" WS. (2) 11 blade 64mm fans, 3500 kv motors, 80 Amp ESC's, (2) 2600 mah 50C 4S
batteries, 63 ounces all up, almost 7 lbs of thrust (measured),
50% KFM-2 wing.
Wings and feathers are .206" (5mm) paper faced foam board (Elmer's)
Fuselage is 1/2" (12mm) nominal Owens Corning Formular Pink EPS (Extruded Polystyrene)
Nacelles are cut from 2" (50mm) Formular with a hot wire
»Old_Pilot« hat folgende Bilder angehängt:
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »Old_Pilot« (6. Mai 2021, 18:26)
Donnerstag, 6. Mai 2021, 18:21
Looks beautiful :ok:
Old_Pilot
Donnerstag, 6. Mai 2021, 18:56
Northrop YA-9A Foamie - Part 1
So... the first things I cut were the servo tray, the stab spars, and the wing mounts, and the templates I'll use to cut the nacelles with a hot wire,
»Old_Pilot« hat folgendes Bild angehängt:
Donnerstag, 6. Mai 2021, 19:07
Nice :ok:
Looks a little bit like Iskar ;)
LG Frank
T-rex 550 E DFC
Goblin BT Sport 700 :heart:
Iskra von Jürgen Be :heart:
Canadair CL- 215 von Heinrich G. 8)
Eflight Viper Jet 6S 70mm EDF
Mein Verein: https://www.facebook.com/modellflughontheim
Old_Pilot
Donnerstag, 6. Mai 2021, 21:23
What is Iskar ? other than a river in Bulgaria
Donnerstag, 6. Mai 2021, 21:59
Jürgen Be
Beruf: Postler
Donnerstag, 6. Mai 2021, 23:20
Schönes Modell die Northrop YA-9A :ok:
Hat aber meiner Meinung nach mit der Iskra nun gar nix gemeinsam...
Jürgen
Mein Verein:
http://hmsv.net/
Old_Pilot
Donnerstag, 6. Mai 2021, 23:41
Iskra vs YA-9A
I looked up the Iskra, and I can see some similarities, especially in plan view.........but that's pretty much where it stops.
Thank you for your kind words......though the first attempt to fly the YA-9A ended in disaster....the attached pic is reminiscent of
Godzilla looking over his shoulder because his tail is on fire..the crash was spectacular
Hilmar
Freitag, 7. Mai 2021, 10:20
oh!
8(
I might guess there's not too much left over to be re-used?
What happened? How did it behave within its short flight?
Herzlichst
Hilmar.
Old_Pilot
Freitag, 7. Mai 2021, 12:26
It was SPECTACULAR !....She was flying just fine, so I decided to open the throttles......and then....the fans quit, lots of smoke trails, and in she went...First thoughts are that two high amp draw fans and one high C (60C) battery are OK...until you try to push that much amperage through one Deans plug....pretty sure that's where the fire started..looks like I let the smoke out of everything....total loss...but it was worth watching the crash !..........LOL..max amperage draw on each fan was close to 60...so I was pushing almost 120 amps through one Dean's plug.....
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »Old_Pilot« (7. Mai 2021, 12:47)
Freitag, 7. Mai 2021, 12:53
Hello, I only use XT 90 with an ESC over 40 A.
Over 60 A I take AS150.
I am always very skeptical about this and measure the current on each model
LG Frank
T-rex 550 E DFC
Old_Pilot
Freitag, 7. Mai 2021, 15:41
Northrop YA-9A Foamie Part II
I cut the wings, feathers, and skids yesterday, and spent this morning assembling.......
Control surface hinges are 1" masking tape, top and bottom
Spars are 0.156" sq carbon fiber tube
KF plates are glued to the bottom plate with M-45 spray adhesive
Single bevel on the control surfaces
Top and bottom bevel on the leading edge of the wing
Gonna cut the fuselage this morning
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »Old_Pilot« (7. Mai 2021, 15:47)
Old_Pilot
Sonntag, 9. Mai 2021, 13:52
Progress on the A9
Got the fuselage cut and framed up........love my fuselage jig
Old_Pilot
Dienstag, 11. Mai 2021, 19:32
YA-9 Progress
Finally got back the the YA-9.....1st dry fit...the 20 deg saddle for the stab is almost perfect.....
so now I have to get my hot wire bow hooked up and cut the nacelles and nose block..
Lots of sanding and surface prep to do.....
Old_Pilot
Mittwoch, 19. Mai 2021, 17:26
Back to the YA-9A - More progress
Finished shaping and rough sanding.....now to fill in the dings, finish sanding, surface prep and paint
Old_Pilot
Donnerstag, 20. Mai 2021, 20:07
Northrop YA-9A - Almost flight ready
Down to push rods and control horns. A friend of mine is going to 3D print the napalm cannisters for the 10 hardpoints under the wing...
The graphics are superb.....between a new Epson 2760 printer and the Avery vinyl, I can't buy anything any easier or better
Dieser Beitrag wurde bereits 2 mal editiert, zuletzt von »Old_Pilot« (21. Mai 2021, 13:08)
F3B
Freitag, 21. Mai 2021, 07:25
:ansage: Fantastic Model,
:ok: :applause: :ok: :applause: :ok:
Greetings...
Thomas :w
Old_Pilot
Freitag, 21. Mai 2021, 13:27
Oops !
I just realized that the nose graphics are incorrect.....I'll fix it this morning
Freitag, 21. Mai 2021, 13:37
That was really quick. :ok:
Neatly built.
8)
LG Frank
T-rex 550 E DFC
Old_Pilot
Freitag, 21. Mai 2021, 13:50
Build time
Mr. Frank
Thank you for your kind words.....but I have a confession to make....I cut all my airframes on my CNC machine,
which reduces the overall build time considerably. Plus, I had already developed the drawings and cut files for
this one's sister.....
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »Old_Pilot« (21. Mai 2021, 14:05)
