Samstag, 15. Oktober 2016, 14:58
Wow
Results of DIY. A bar set very high. Congratulations.
Montag, 14. November 2016, 03:29
136 plus mph (218.87 kph) on 4s lipo
here is a 133.29 practice run
Congratulations to Brian Buaas
Donnerstag, 17. November 2016, 09:00
Here is the record run.
The date is wrong. It should be 11/13/16
Montag, 21. November 2016, 02:23
"Thanks Guys.
I'm going to do something I rarely do: Here's the entire setup.
Disclaimer***this setup is right at the very edge of the equipment capability!!! Use at your own risk. This boat is a product of 3 years of tuning.
Hull- Raptor tub, SAW front sponsons, no rears.
Motor- TP3650 2Y 3080kV
ESC- Castle Creations Edge Lite 200 with added cooling tubes and conformal coating.
Batteries- Dinogy Graphene (4S2P 3300's).
Prop- ABC 1823-19-38 (2) cll S/B (snowman prep :D).
Driveline- .150 double square cable with teflon liner into Hyperformance outboard stub shaft.
We don't do this stuff in a vacuum. Thanks to my friends for all the help and brain storm sessions over the years: Mark, Darin, Tyler, Jim, Joe. In other words, the usual suspects! We're not done yet.
Finally, here's the reason for posting the info: It's essentially an off the shelf system. It's proof of what can be done with the incredible equipment that's available to all of us. It's also a reminder how careful we all need to be with how and where we run these things, be safe. Last but not least, it's a starting point and an invite to anyone who might be interested in joining us at time trial events. These events are great fun both on and off the water."
~ Brian Buaas quoted from IW~
